54 heater def. switch - NCRS Discussion Boards
  • Roy B.
    • February 1, 1975
    • 7044
    That's right ground the housing *NM*
    • Brad H.
      • August 12, 2007
      • 724
      Re: 54 heater def. switch
      Roy, tapped on heater housing several times and in low the fan spins but how fast I don't know what it is supposed to rev at, but it does seem to work. Does mean the bearing or squirrel cage or motor windings and can one spray lube in their somehow to free things up if that is a cure? Thanks again Brad
      • Brad H.
        • August 12, 2007
        • 724
        #18
        • Roy B.
          • February 1, 1975
          • 7044
          #19
          OK it should spin about 1/2 at low or even less using 6Volts but if you needed to tap it to spin it may need lube,Old trick was to drill a small hole at the vary rear and shot some oil in it to free the bearing .
          But the fact is it will run at a low speed . So it seems your switch is bad and not the motor. The switch does have a white ballast ?? It drops the volts to the motor to run at low speed
          • Roy B.
            • February 1, 1975
            • 7044
            #20
            • Brad H.
              • August 12, 2007
              • 724
              #21
              Roy, yes the switch has the white ballast new from Corvette specialists of maryland. Thanks Brad.
