54 heater def. switch - NCRS Discussion Boards
  • Brad H.
    • August 12, 2007
    • 724
    purchased the 53-57 heater defr. switch from C S of Md. for the 54 hooked it up on the carpet did not install in dash yet to just check. One speed worked fine seemed to be the high and the other had a little of noise out of heater unit like was trying to go, switch got very hot and popped breaker. There are only two terminals on this, hooked fuse wire closest to fuse side term. and heater wire closest to heater side term. and this is with flat spot on switch facing down. was up. Brad
  • paul bowers
    Re: 54 heater def. switch
    BRAD,
    IS THAT THE SWITCH THAT TURNS AND ALSO PULLS IN AND OUT?
    ALSO WHAT DID THEY CHARGE FOR SWITCH?
    PAUL sorry about caps
    • Roy B.
      • February 1, 1975
      • 7044
      [One speed worked fine seemed to be the high and the other had a little of noise out of heater unit like was trying to go, switch got very hot and popped breaker.}
      make sure the heater motor has a GOOD ground or the motor bearing is sticking.
      • Brad H.
        • August 12, 2007
        • 724
        Sorry for delay, power has been out for 1 week from storm. Yes low and hi and defrost pulls out. Corvette Specialists of Maryland can price it for you. Thanks Brad.
        • Brad H.
          • August 12, 2007
          • 724
          Sorry power has been out from storm. Roy, switch works fine hooking up both ways. (switching terminals). But only one speed. Seems I have only high because my 58 high sounds like only speed I have for 54 car. If I hook up one way It runs on the right side or high, if hooked up the other way it runs on the low side. It is just laying on the floor now for checking. Can motor alone from under hood be taken out and service the motor or do I have to dismantle everything, Dont want to do that if I dont have to. Thanks again Brad.
          • Roy B.
            • February 1, 1975
            • 7044
            I don't know . It's the switch or motor, if you have a battery charger run and hook to the motor 12V for high speed then 6V for low speed and if the motor runs on ether then the switch is bad =simple !!
              • August 31, 1999
              • 155
              Should you decide you need a replacement, Corvette Specialties of Maryland (8000-638-6450 - no website) has them available. $139 + shipping.
                • August 31, 1999
                • 155
                • Brad H.
                  • August 12, 2007
                  • 724
                  Roy, switch is new from CS of M. Again can motor be taken out by itself undewr hood and checked or does entire heater unit have to be taken out and taken apart? thanks Brad.
                  • Brad H.
                    • August 12, 2007
                    • 724
                    • Roy B.
                      • February 1, 1975
                      • 7044
                      No you need to remove the whole heater, did you try 12V and 6V to see if the motor ran on both?? The car motor is the same BUT has two wires Not one like Corvette
                      • Roy B.
                        • February 1, 1975
                        • 7044
                        • Brad H.
                          • August 12, 2007
                          • 724
                          Roy, not a electrical testing guy. What exactly hooks to what to test hi and low, pos bat term to wire coming of motor under dash and also ground of bat term to ground somewhere? Thanks Brad.
                          • Brad H.
                            • August 12, 2007
                            • 724
                            • Roy B.
                              • February 1, 1975
                              • 7044
                              That's right ground the housing *NM*
