Carb rebuilders - NCRS Discussion Boards
Carb rebuilders
  • Steve H.
    • November 1, 1996
    • 118
    Carb rebuilders
    Are there any recommendations on rebuilders for a '67 #3810 carb? It runs ok but leaks around the shaft and onto the intake.
    Steve
  • Gerard F.
    • June 30, 2004
    • 3806
    Re: Carb rebuilders
    Steve,
    If that's the only problem, and the rest of the carb is in good shape. You can buy a new 3810 throttle plate assembly for about $130. Check on ebay, mztrcarb?
    That would be the fastest fix, again if that's the only problem.
    Jerry Fuccillo
    #42179
    Jerry Fuccillo
    • Gerard F.
      • June 30, 2004
      • 3806
      Re: Carb rebuilders
      Steve,
      Jerry Fuccillo
      #42179
      Jerry Fuccillo
      • Clem Z.
        • January 1, 2006
        • 9427
        Re: Carb rebuilders
        sounds like the float level is too high if this happens when the engine is shut off. if fuel drips onto the butterflys it will run out the shaft since there is not any type positive seal there to prevent the fuel from leaking out
        • Clem Z.
          • January 1, 2006
          • 9427
          Re: Carb rebuilders
          • Tom B.
            • March 1, 1978
            • 720
            • Tom B.
              • March 1, 1978
              • 720
              • Tom B.
                • March 1, 1978
                • 720
                Re: Carb rebuilders
                I don't know where that goofy looking y came from but his name is Kunz.
                • Tom B.
                  • March 1, 1978
                  • 720
                  Re: Carb rebuilders
                  • Steve H.
                    • November 1, 1996
                    • 118
                    Re: Carb rebuilders
                    Thanks guys,
                    As the carb has a hesitation when accelerating I think will give Bob Kunz a call.
                    Steve
                    • Steve H.
                      • November 1, 1996
                      • 118
                      Re: Carb rebuilders
                      Thanks guys,
                      Steve
