Which Bolt Headmarks ??? - NCRS Discussion Boards
  • Anthony S.
    • April 3, 2008
    • 183
    I have seen numerous E-Bay auctions for "correct" Valve Cover, Q-Jet & Fan Shroud bolts.
    They range from headmarks such as:
    Valve Covers - "L" "E"
    Q-Jet - "TR" "CH" "SBC"
    Fan Shroud - "L" "E"
    I've checked my Judging Manual (3rd Edition) to see what is correct for these three areas but it does not mention head markings. I didn't have much luck in the archives either.
    Also, does my carb use 4 bolts or 3 bolts & a stud (accelerator bracket)?
    My car is a '68 327/300 with P/S, A/C & it has a metal fan shroud.
    Is this covered somewhere else that I'm missing?
    Anthony
    • 43240
    Re: Which Bolt Headmarks ???
    Anthony-----
    Many different bolt headmarkings were used in PRODUCTION for certain fastener positions. The bolts seen on eBay might have been typical of those used for certain applications/fastener positions, but are not necessarily the ONLY ones used.
    Your application originally used 2 bolts (long, for the forward positions) and 2 studs for the rear positions for carburetor-to-manifold fastening. The left rear stud retained the accelerator cable bracket.
      • 43240
      Anthony-----
      • Anthony S.
        • April 3, 2008
        • 183
        Thanks Joe, your help is always appreciated.
        • Anthony S.
          • April 3, 2008
          • 183
