67 C-2 bell housing - NCRS Discussion Boards
67 C-2 bell housing
  • Dale S.
    • November 12, 2007
    • 1224
    67 C-2 bell housing
    When cleaning my bellhousing I noted a "3" in black on the passenger side, midway back and half way up. Pretty much in the center. The number "3" is about 2 or 3 inches tall. Is this something that was there from the factory or should I clean it off? Thank you Dale
  • Mike M.
    • May 31, 1974
    • 8403
    Re: 67 C-2 bell housing
    retain or re-mark the "3" is what i'd do. mike
    • Mike M.
      • May 31, 1974
      • 8403
      • Dale S.
        • November 12, 2007
        • 1224
        Ok Mike, I will retain it. It happens to be on a clean spot. I wonder if anyone else has seen this.Dale
        • Dale S.
          • November 12, 2007
          • 1224
          • Peter L.
            • May 31, 1983
            • 1930
            Dale - I agree with Mike, keep it. While I haven't seen a "3" specifically, it appears it was common practice to to mark "info" such as the engine code on bell housings. Pete
            • Peter L.
              • May 31, 1983
              • 1930
              • Kent K.
                • December 1, 1982
                • 1139
                Dale --- How about posting a photo of the mark?
                Reagards, Kent Keech
                Kent
                NCM Founder - Member #718
                • Kent K.
                  • December 1, 1982
                  • 1139
                  Kent
