Motor Oil - NCRS Discussion Boards
Motor Oil
  • Bill Purdy
    Motor Oil
    Hi , Can someone tell me what 10W30 SE CC motor oil would be used for. I know this is not directly a Corvette question but I'm sure there is someone here who can help. Thanks in advance, Bill
    • 43260
    Re: Motor Oil
    Bill-----
    "SE" was an API oil rating used for gasoline powered engines built from ABOUT 1972 to ABOUT 1978 or 79. "CC" is, in this case, a secondary diesel engine oil rating from about the same period. 10W-30 was probably the most widely manufacturer recommended engine oil viscosity rating of the 70's and continuing right to this day (although 5W-30 has pretty much taken over for most GM cars).
    So, this oil is from the pre- ABOUT 1979 era. Technically, it should not be used in later model vehicles.
      • 43260
      Re: Motor Oil
      Bill-----
      • Bill Purdy
        Re: Motor Oil
        Thanks Joe, This board and You are great !
        Bill
        • Bill Purdy
          Re: Motor Oil
          Bill
