C1 Parking Brake Flasher - NCRS Discussion Boards
  • Mike E.
    • February 28, 1975
    • 5138
    What does the 642 fit?
    What was the original application for the 642?
    • Mike E.
      • February 28, 1975
      • 5138
      • Bernard M.
        • August 31, 1994
        • 341
        #18
        Re: What does the 642 fit?
        The 642 flasher is intended for use at 12V with a #57 bulb. It can be used from 6V to 32V as long as the bulb used with it produces the same current. My dad's '58 Buick used one but I'm sure it was used in many other applications as well.
        • Bernard M.
          • August 31, 1994
          • 341
          #19
          • Brett H.
            • January 1, 1996
            • 367
            #20
            Re: C1 Parking Brake Flasher
            I agree completely. The switch is most likely your problem. They are very sensitive. There's usually a trick when pulling the handle out to make it work correctly (most) of the time. Like during judging!!!!
            You CAN rebuild it like in the previous post.
            • Brett H.
              • January 1, 1996
              • 367
              #21
