C1 Parking Brake Flasher - NCRS Discussion Boards
  • Paul Bishop
    Hi, I've been having a few problems with the parking brake flasher on my 1956. When the handbrake is applied and the ignition on sometimes in doesn't work, sometimes it flashes and the other times it stays lit. Have checked connections & fittings etc and it appears that the Tung-Sol 650 flasher is at fault, boy are they difficult to find especially as I'm in the UK. Does anyone know where I can find one, have checked Ebay and a chap called Jay who seems to be the main man for flasher units on there. Or maybe someone on here has one tucked away in the cupboard that would like to sell it and give it a new home, I would be internally grateful.
    Thanks in advance,
    Paul.
    Re: C1 Parking Brake Flasher
    Paul -
    That's a very rare and costly part. You might try Mary Jo Rohner (www.vettegal.com) or Grossmueller's (www.gccorvettes.com) .
    • Pierre J.
      • July 31, 2000
      • 193
      MJ has several advertised on eBay
      Pierre
      34410
      • Richard T.
        • February 1, 1979
        • 858
        Paul,
        People have repaired those flashers. Some where in my library I have a copy of a "How To" on the subject. The basic idea is to open the back of your flasher to expose the bi metallic element, it can be removed and replaced with an element from a modern parts store flasher. Solder the new element in and your all set. I have not personally tried this repair so cannot be sure but in theory it makes sense. I'll try and find the article for you. Rich # 2272
        • Paul Bishop
          Thanks again, super helpful as always!
          Kind Regards,
          Paul.
          • Richard T.
            • February 1, 1979
            • 858
            Paul,
            Paul please send me your e mail address and I'll send you a copy. Rich
            • Mike G.
              • July 31, 2002
              • 709
              vet gal has some nos ones. i got one for my 57
              • Bernard M.
                • August 31, 1994
                • 341
                Did she send you a 650? The most readily available 12V one is a 642, which will likely work but won't pass judging. Paul, The article referred to in above posts is still available on the St. Louis NCRS website in one of the older newsletters. If you can't find it there, let me know. I wrote it and I can send you a copy via email. Bernie Myers
                • Mike G.
                  • July 31, 2002
                  • 709
                  must have been the correct 650 because i did not get a deduct for it.
                  • Paul Bishop
                    Thanks again guys, Rich is sending me the article so may have a go a fixing it myself.
                    Kind Regards,
                    Paul.
                    • David B.
                      • July 31, 2004
                      • 330
                      Bernie,
                      I didn't see it on the St Louis site. If possible, would you mind sending me a copy?
                      Dave B. '57
                      Dave, 1969 427, 1957
                      Previous: 1968 427, 1973 454
                      • Pierre J.
                        • July 31, 2000
                        • 193
                        Check this site
                        Pierre
                        34410
                        • Pierre J.
                          • July 31, 2000
                          • 193
                          Check this site
                          Pierre
                          34410
                          • Bernard M.
                            • August 31, 1994
                            • 341
                            It appears some of the old issues are no longer posted. You have mail.
                            • Bernard M.
                              • August 31, 1994
                              • 341
