67 L79 Water Pump Belt - NCRS Discussion Boards
  • James B.
    • December 1, 1992
    • 281
    I recently bought a 67 L79. the water pump belt looked very loose; it was probably a Napa belt. I ordered a 'correct' one from C Central, wrapped belt I assume made by Quanta. That belt is also loose allowing for about 1/2" deflection with little pressure, and of course there is no adjustment on the WP belt. My crank and WP pulleys are original as is the water pump so I cannot think of anything that is off in the hardware. I have no belt squeal and a restorer/friend says it probably isn't a problem as I have 50% wrap on both pulleys in addition to the alternator pulley belt. I could just go to Napa and get a belt 1/2" shorter but I plan to have the car judged and would like to get the correct length belt- any thoughts or info would be appreciated. Thanks, Jim Baker
  • Gary B.
    • February 1, 1997
    • 7024
    Jim,
    Are you talking about the captive belt that goes around just the water pump and crank pulleys? Do you know what Quanta part number yoy got? And do you know the outer circumference of the belt? I have a Quanta belt for my '66 L79 at home that I can measure when get home tonight.
    Gary
    • James B.
      • December 1, 1992
      • 281
      Re: 67 L79 Water Pump Belt
      Yes, I am talking about the captive belt that goes around the water pump and crank pulleys. No, I didn't think to measure the belt. thanks for response.
      • Gary B.
        • February 1, 1997
        • 7024
        Jim,
        Measure your belt with a cloth tape measure around the outside and I'll do the to mine. Since my Quanta belt is new and never installed, if we get the same measurement it suggests that I will have the same problem when it comes time for me to install the belt. But it my belt is shorter, that might be useful information.
        Gary
          • 43221
          Jim------
          Reproduction belts usually have the GM part number embossed on them (or, printed in the case of 73+ belts). So, what is the number on yours?
          • Mark G.
            • March 1, 2001
            • 227
              • 43221
              Mark-----
              GM #3837810 is the one.
              • Gary B.
                • February 1, 1997
                • 7024
                Jim,
                My Quanta belt is GM # 3837810 and the length along the outside is 34 3/8".
                Gary
                • Greg T.
                  • January 1, 2004
                  • 136
                  Quanta sells a long and short version of the belt. Try the short one.
                  Home > RESTORATION FAN BELTS > GM FAN BELTS > CHEVROLET BELTS > Corvette > 1966 - 1967 Small Block
                  1966-1967 Corvette Water Pump Belt, S.B. 350 HP w/o AC & PS
                  Item Number : 29-B-075B
                  Unit Price: $24.00
                  Applications: 1966 - 1967 Corvettes with 350 Horse Power engines, without Air Conditioning, without Power Steering
                  Features: Cloth-wrapped with GM emblem, Chevrolet part number, broadcast code (where applicable), belt size (where applicable), manufacturer's symbol and construction codes
                  Original Part Number on Belt: 3837810. Short Version
                  GM Restoration Part Produced by Quanta under license from General Motors
                  Packaging: Sleeved
                  Part Number: 29-B-075B
                  • Gary B.
                    • February 1, 1997
                    • 7024
                    Jim, how did your belt story turn out?
                    Jim,
                    In the end, did it turn out that you had the "long" version of the Quanta's L79 belt?
                    Gary
                    • James B.
                      • December 1, 1992
                      • 281
                      Re: Jim, how did your belt story turn out?
                      Gary, I am not sure yet. I don't have time to work on the car now. I assumed I had the long belt and have ordered the short one from Quanta. We're going to be gone for a couple of weeks so late this month I will try to put it on. Will try to remember to send you a follow-up when that is done. Send me a short email (jmbvette@aol.com) if you don't mind so I have your email address, that will also help jog my memory; thanks,Jim Baker
