65 350HP, alternator location, left or right?? - NCRS Discussion Boards
  • William B.
    • April 30, 1975
    • 942
    I am looking to purchase a 65 327/350, 4 speed, no power steering or power brakes car. The alternator is on the right/passengers side, is this corect? I have been looking at a number of pictures and I see the alternator is mounted on left and right. Which side is cirrect for the car I am looking at?
  • John S.
    • September 30, 1997
    • 263
    Re: 65 350HP, alternator location, left or right??
    Bill,
    If your car doesn't have air conditioning, then the alternator should be mounted on the right (passenger) side. On A/C cars or big blocks, the alternator is mounted on the left (drivers) side.
    • William B.
      • April 30, 1975
      • 942
      Thanks for the response. What if the car was a previous fuel car?
      • John S.
        • 263
        Bill,
        On '65 fuel cars the alternator is on the right (passenger) side.
        • William B.
          • April 30, 1975
          • 942
          Thanks again, car in question is correct. *NM*
          • Joe R.
            • March 1, 2002
            • 1356
            Hi Bill:
            As others have noted, the alternator should be on the passenger side unless the car has A/C, in which case the alternator was moved to the driver's side.
            I'm curious about something that perhaps you can check for me. Does the driver's side exhaust manifold appear to have provisions for mounting an alternator? The provisions that I *think* should appear on the driver's side manifold (casting 3846563?) are a forward-facing boss with two threaded holes for bolts that run parallel to the crankshaft. I think that when they installed A/C they simply moved the alternator to this location, without changing the exhaust manifold.
