bolt size C-3 - NCRS Discussion Boards
bolt size C-3
  • Lyndon S.
    • April 30, 1988
    • 1027
    bolt size C-3
    Does anyone have the specification for the bolt that goes on the side of the block for the starter brace on a big block? Would like the sized used. Thanks
    Kelly
  • Verle R.
    • March 1, 1989
    • 1163
    Re: bolt size C-3
    Kelly,
    I believe the bolt is a 5/16 NC about 5/8" long. Actual length could be 3/4".
    The bolt secures the starter brace and ground cable.
    It is a blind hole so don't use a bolt that is too long. It will bottom out and could punch into the water jacket.
    This is going on recent memory, not from documentation or a tape measure.
    Have you ever heard of CRS?
    Verle
    • Lyndon S.
      • April 30, 1988
      • 1027
      Re: bolt size C-3
      The bolt should run through the chrome heat shield also right?
      • Verle R.
        • March 1, 1989
        • 1163
        Re: bolt size C-3
        The car I worked on did not have the shields in place.
        I am more familiar with small blocks and they have separate holes (1/4 20) for shield brackets.
        I believe big block plug shields are attached by an exhaust manifold bolt near each plug.
        Remember CRS?
        Verle
          • 43242
          Re: bolt size C-3
          Kelly-----
          Yes.
          • Lyndon S.
            • April 30, 1988
            • 1027
            • Lyndon S.
              • April 30, 1988
              • 1027
              Re: bolt size C-3
              I take it that it must be discontinued?
              • Verle R.
                • March 1, 1989
                • 1163
                Re: bolt size C-3
                Kelly,
                Are you referring to the solenoid heat shield?
                Verle
                • Lyndon S.
                  • April 30, 1988
                  • 1027
                  Re: bolt size C-3
                  yes the heat shield on the solenoid.
                    • 43242
                    Re: bolt size C-3
                    Kelly-----
                    Yes, I believe that the order of things is as you described.
                    The exact bolt used for the application was never available from GM in SERVICE. However, there was nothing special about it, at all. Just a standard hex head bolt.
                      • 43242
                      Re: bolt size C-3
                      Kelly-----
                      It's discontinued but an excellent reproduction is available.
                      • Lyndon S.
                        • April 30, 1988
                        • 1027
