I have a 7029207 service replacement carb dated early 74 that I will be using on my 69 L36 until I find the correct 7029204 carb. I picked up a carb kit for the 207 carb and noticed that some of the adjustments between the two carbs are different, float level being one of them. So, should I use the specs for the 207 carb or seeing as it will be used on my 69 L36 and the 207 carb does replace the 204 carb, should I use the 204 adjustment specs on this 207 carb or stay with the 207 specs?
Greg Linton
#45455
Greg Linton
#45455
