C3 points again - NCRS Discussion Boards
C3 points again
  • Lyndon S.
    • April 30, 1988
    • 1027
    C3 points again
    Points again
    I set the point the first time using the tune method with me turning the points till it misses them backing off
    That should put them at 30 degrees right or close? I lost my dwell meter, so I borrowed one from a friend and put it on today and it was showing a bout 10degrees but when I turn the points the scale does not move. I hooked it positive lead to the coil and then black on the bracket on the engine that holds the radio shield. Do I have it on the car right? How good is setting the points the way you just listen to the engine ? Thanks
    Kelly
  • Lyndon S.
    • April 30, 1988
    • 1027
    Re: C3 points again
    Also with each method should the vacuum advance be undone?
    • Donald L.
      • September 30, 1998
      • 461
      Re: C3 points again
      My dwell meter has 4 leads. Two leads are for power and on the others one hooks to the neg side of the coil and one to ground. You do not have to disconnect the vacuum line to set the dwell.
      • Michael W.
        • April 1, 1997
        • 4290
        Re: C3 points again
        Setting the points 'by sound' is about as accurate as target shooting wearing a blindfold. At least get them close by using a feeler gauge to start with.
        Once the dwell is properly set, make sure you check the initial or total timing- with a timing light.
          • 15692
          Re: C3 points again
          You can't set points by "ear". As the dwell/gap changes the timing changes, which will affect engine speed.
          If you don't have an accurate dwell meter set them at the CSM recommeded gap, then set the initial timing to spec.
          It sounds like your dwell meter connections are correct. Be sure you are on the correct scale and verify dwell meter function on another engine. If it's okay then the distributor may have a mechanical problem.
          • Phil P.
            • April 1, 2006
            • 409
            positive lead to dist side of coil not ign.side
            points can be set pretty close turning the adjust screw ,while engine is running, clock wise till mis-fire back off ccw 1 turn then cw 1/2 turn---good luck,phil
              Re: positive lead to dist side of coil not ign.sid
              If you don't have a functional dwell meter, set them at .019" for new points or .016" for used points; that will get you pretty close until you can put a dwell meter on them.
              • Lyndon S.
                • April 30, 1988
                • 1027
                I got them set at 30, I had the wires on the coil wrong! Thanks guys for all the help
                Kelly
