GM #102647 Castle nut N40 - NCRS Discussion Boards
  • Ian S.
    • June 30, 2002
    • 264
    Hello,
    The AIM lists part number 102647 as the castle nut that secures the pitman arm to the power steering control valve. Long island corvette calls for the same castle nut for both power steering cars and non power steering cars but the nut from them is too tall. Can someone confirm that the nut used for N40 cars is unique? I can't find the part number for non powered steering cars.
    Ian
    • 43236
    Re: GM #102647 Castle nut N40
    Ian------
    As I recall, the nut used for both power steering and non-power steering applications was the same. However, that does not mean that the nut sold by LI is the correct one for either application.
    The correct nut is NOT a castle nut (aka castellated nut). No castle nuts were used on any 63-82 Corvette. The correct nuts are SLOTTED NUTS. THERE IS A DIFFERENCE BETWEEN A CASTLE NUT AND A SLOTTED NUT.
    When I get home, I can provide a GM part number for a currently available slotted nut that will be virtually identical in every way to the nut originally used.
    • Ian S.
      • June 30, 2002
      • 264
      Thank you Joe! *NM*
        • 43236
        Ian-----
        Order nut GM #9440974. It should be virtually identical to the original nut in all respects.
        • Ian S.
          • June 30, 2002
          • 264
          Thank you again! *NM*
