I need an education on electric chokes - NCRS Discussion Boards
  • Chuck R.
    • April 30, 1999
    • 1434
    Having never dealt with one other than to adjust it, I'll be putting an electric choke carb on my engine and need to learn how to wire it up.
    Any overly simplistic explanations out there?
    Apprciate any help,
    Chuck
  • Clem Z.
    • January 1, 2006
    • 9427
    wire it to a full 12 volts that is controlled
    off and on by the ignition key
    • Chuck R.
      • April 30, 1999
      • 1434
      Re: Ok.......
      So the negative side go's to a good ground and the positive to a switched twelve volt power sourse...........cool!
      I was hoping that there wasn't some freakin sensor or probe involved.
      Thanks Clem I appreciate it,
      Chuck
        Re: Ok.......
        Chuck -
        Don't power it from the coil (+) terminal like some folks do - the choke needs a full 12 volts, and the coil (+) terminal is fed through a resistance wire (serves the same function as the separate ballast resistor on pre-'68 cars).
        • Chuck R.
          • April 30, 1999
          • 1434
          Re: Roger that *NM*
            • 43235
            Re: Ok.......
            Chuck------
            Some do use an external heat sensor. However, even if they do, the wiring is quite simple.
            • Jim T.
              • March 1, 1993
              • 5351
              Re: I need an education on electric chokes
              Chuck look on the fuse block and you will see where you can connect a wire to the space provided labeled "ign" and run the wire through the firewall to the electric choke. This will give you 12 volts when the key is in the "on" position.
              • Clem Z.
                • January 1, 2006
                • 9427
                if the car has a alternator one of the plug in
                wires is 12 volts controlled by the ignition switch
                • Chuck R.
                  • April 30, 1999
                  • 1434
                  Re: Excellent information
                  Thanks Gents, I'm on my way.
                  Chuck
                  • Christopher R.
                    • March 31, 1975
                    • 1599
                    You want 12 volts controlled by the ignition switch that's close by. On a C1 and at least some C2s, the closest is the ignition switch side of the ballast resistor. The ignition switch side is the full 12 volts. The side that goes to the distributor is less than 12. Windshield wiper is also close by.
                    This circuit is not fused. That made me nervous. When I did mine, I spliced an in-line fuse in. 10 amps, I believe.
                    • Chuck R.
                      • April 30, 1999
                      • 1434
                      I'm leaning towards the alternator connction as it will reduce the length of wire required to reach both the fan unit and thermal switch.
                      Chuck
