68 Windshield Washer Pump Help - NCRS Discussion Boards
  • Mark Stocki
    Per the NCRS judging guide the washer pump for 1968 is supposed to be white. The one in my car is black. I looked through Dr. Rebuild's catalog (page 63)and they show a 68-73 pump as being black (although they do sell a white repair kit, not including the pump cover). Can anyone help with what I need & where I can get it? Thanks!
    • 43238
    Re: 68 Windshield Washer Pump Help
    Mark-----
    The GM/Delco SERVICE parts have been black for MANY years. I don't know if the "white" versions, as original, are being reproduced now, or not. I don't recall having seen them.
    • Geoff C.
      • May 31, 1979
      • 1613
      ain't never seen a Whitey one I din't like *NM*
      • Terry B.
        • August 31, 1999
        • 607
        1968 Wiper Pump
        Mark,
        The part that I believe you are referring to is set on top of the pump and has 3 hoses attaching into it, one intake from the water bottle and two out to the windshield. I had the same problem with the black pump and then went with the white in a rebuild kit. If you are not having the car judged white would be correct. However if you are having the car judged, it should be yellow with age. I bought my yellow one at Eastern Corvettes. Contact Steve or Mike at http://www.easterncorvettes.com Hope this helps.
        Terry Buchanan
        Webmaster / Secretary - Heart of Ohio Chapter www.ncrs.org/hoo
        Corvettes Owned:
        1977 Coupe
        1968 Convertible 427/390 (L-36) Chapter Top Flight 2007, Regional Top Flight 2010, National Top Flight 2011
        2003 Electron Blue Coupe
        2019 Torch Red Grand Sport Coupe
          • 43238
          Re: 1968 Wiper Pump
          Terry-----
          The original pumping units were completely "white", including both the piston/cylinder assembly and the valve assembly (i.e. the top part with the hose nipples). It's not too hard to find a "white" valve assembly. They're for sale on eBay all the time and you can even get them in the Dorman/Help! section of auto supply stores. While these valve assemblies are "white", they can be rather easily discerned from original valve assemblies.
          Finding the piston/cylinder assembly in "white" is another matter. That's the part that I was mainly referring to in my last post. Of course, one can put a "white" valve assembly on a later black piston/cylinder assembly, but that's not going to create a "correct" unit that will pass judging scrutiny.
