1965 Muncie Trans - NCRS Discussion Boards
1965 Muncie Trans
  • Joe Ciaravino
    1965 Muncie Trans
    I am trying to determine the casting numbers for the main case, side cover, and tailshaft housing for a May 1965 car. These items are not judged, and do not appear in the NCRS manual. Also, does the speedo cable exit the left or right side of the tailhousing.Thanks in advance.
    Joe
  • Dan 80
    Re: 1965 Muncie Trans
    Main Case Casting # 3851325
    Side Cover Casting # 3831707
    Tail Shaft Housing Casting # 3846429 till around Feb '65 then 3857584 The first one has the speedo on the drivers side and the second has it on the passenger side and the later main cases may have the larger countershaft? Can't remember.
      • 43240
      Joe-----
      Maincase= 3851325
      Extension housing= 3846429 (to 2/65) uses right side speedo drive
      3857584 (after 2/65) uses left side speedo drive
      Side cover=3831707
      • Bill Clupper
        As an aside, I own two cars in the 6500 serial number series with original trans and pass side tailshaft configurations. This would lead me to beileve the change was early Jan for the pass side configuration.
        • Wayne M.
          • March 1, 1980
          • 6414
          Bill --- I'll go you one better; my # 01487 (Sept 16th assy) trans has the "584" tailshaft with speedo cable attached to the passenger side. Examining the AIM, I see no evidence (rev #, etc.) that a '65 M20 trans in a Corvette ever had a driver side speedo output. This Feb '65 changeover business comes from Colvin.
          • Dan 80
            I have '65 car #684 and it has the driver's side speedo output.
            • Bill Clupper
              I agree, My perswonal experience has been that almost all '65s used the later configuration. I owned #838 once, but it was so long ago I don't remember what side it was on. ( Pre-NCRS days)
