'66 L79 H2O pump fittings - NCRS Discussion Boards
  • Rob A.
    • December 1, 1991
    • 2126
    Were both the bypass and heater hose fittings installed prior to engine paint and receive some degree of overspray?
    • 43221
    Re: '66 L79 H2O pump fittings
    Rob-----
    The bypass nipple on the waterpump was installed at Flint and may show some orange overspray. The heater hose nipple was installed at St. Louis and, consequently, should have no paint, at all.
    • Rob A.
      • December 1, 1991
      • 2126
      Thanks... *NM*
      • Tom D.
        • September 30, 1981
        • 2134
        Joe: Can I assume this is true for most C2 engine options?
        Tom D.
        4889
        https://MichiganNCRS.org
        Michigan Chapter
        Tom Dingman
          Tom, just look in your copy of the AIM. If you see the pump nipple called out for assy at the St. Louis plant, then it wasn't with the engine when it was built in Flint/Tonawanda and therefore didn't get painted Chevy orange UNLESS there was some touch-up paint work done...
            • 43221
            Tom-----
            Yes.
