'66 rocker molding lower attaching screws - NCRS Discussion Boards
  • Rob A.
    • December 1, 1991
    • 2126
    The 4 lower screws on my '66 are the round head, phillips that the JM calls for in '67. The JM calls for 1/4" hex head screws for '66. Assuming the JM is correct, and they are different for '66, does anyone know where I can see a picture of them?
  • Randy S.
    • January 1, 2003
    • 586
    Re: '66 rocker molding lower attaching screws
    Rob,
    Are you talking about the screws that screw vertically up into the plastic nuts? The ones I bought from Paragon were phillips.
    Randy
    • Rob A.
      • December 1, 1991
      • 2126
      Randy,
      Those are the ones...the '66 JM says 1/4" hex head screws. I have the phillips as you say. I won't bother looking for the hex head if the JM is incorrect on this.
      • Gary B.
        • February 1, 1997
        • 7035
        Rob,
        I can't locate the orginal ones from my '66, but I know they were definitely not hex heads. Now mine could have been replaced at some point, but I doubt it. Phillips sounds correct.
        Gary
        • Henry J.
          • November 1, 1999
          • 457
          Mine are Phillips also.
          • Rob A.
            • December 1, 1991
            • 2126
            Henry,
            Do yours have washers on them?
            • Peter L.
              • May 31, 1983
              • 1930
              Rob - I believe the 66 TIM&JG is in err and that we have been around the May Pole with this topic several times. Check the archives. Pete
              • Rob A.
                • December 1, 1991
                • 2126
                I'll check....Thanks... *NM*
                • Tom Merkel
                  Re: '66 rocker attaching screws v. '67
                  Rob - This comment relates to rocker panels for '67. I see where you referred to the '67 panel in your post.
                  '67 rockers are attached from the bottom (vertically) by (approx.) 1/4" hex-head screws (approx.) 3/4" long, with a captive washer. This from a original owner non-molested Nov. car. (The head size was peculiar; it may well have been a 3/16"; I had to look around for a smaller nut driver that would fit.)
                  I just had mine off for refurbishment and clean-up last week.
                  Tom
                  • Peter L.
                    • May 31, 1983
                    • 1930
                    Re: '67 rocker attaching screws
                    Tom - Very interesting. Typically we find Phillips head screws in those locarions and the 67 TIM&JG indicates "The bottom of each molding is attached to three stamped sheet metal brackets spot welded to the door sill frame and a stamped steel from bracket by four pan-head black Phillips screws with flat washers." Just shows again they were in the business to make money not cars to the TIM&JG; but my Sept 66 built 67 does have the Phillips head screws with washers and as far as I know they are original to the car. Pete
                    • Henry J.
                      • November 1, 1999
                      • 457
                      Yes, mine have washers.
