p/n 14011058 - NCRS Discussion Boards
p/n 14011058
  • Frank C.
    • January 1, 1986
    • 277
    p/n 14011058
    would someone know the application for these sbc cyl heads? Thx
  • GL Anderson
    Re: p/n 14011058
    14011058
    Bow-Tie
    14011034
    Cast Iron
    190
    64
    I: 2.02"
    Angled
    No
    Off-highway cast iron head
    exhaust 1.60"
    10134392
    Revised
    14011034
    Cast Iron
    190
    64
    I: 2.02"
    Angled
    No
    Latest revision of 14011058-ordering this P/N guarantees obtaining latest casting
      • 43241
      Re: p/n 14011058
      Frank and GL-----
      I'll just add that the GM #14011058 never had any PRODUCTION applications, at all. They were strictly a GMPP SERVICE-only item. However, they can be used for street applications (even though they will have the familiar "for off highway use only" labels on the boxes). The main problem using these heads is that they have no heat cross-over. If using a stock, divorced type choke is important to you (as used for most 1966-74 Chevrolet applications), these heads won't do. It may be possible to drill cross-over passages; I don't know on these heads.
      • Frank C.
        • January 1, 1986
        • 277
        Re: p/n 14011058
        Thx GL & Joe
        • Frank C.
          • January 1, 1986
          • 277
          Re: p/n 14011058
          Hi Joe....because of your comments, I took another look at these heads. Everything you said is right. The boxes do have off road labels you mentioned. They could not be drilled tho for exhaust crossover because there is nothing to drill. This cast (#14011034 dated G015) is completely void of any material in the crossover area. Also note the rocker stud holes are tapped for screw in studs only. Now I just have to figure out what to do with these. They are NOS in the boxes. Boy you sure KNOW your parts!!!! Thx for your reply. Frank
            • 43241
            Re: p/n 14011058
            Frank-----
            The lack of exhaust cross-over may not be a problem as big as you think. I used to think that it was absolutely necessary to have this for choke operation with divorced choke type carbs. However, I've learned some new things recently.
            First of all, one probably does not even need a choke. Second, there are available electric choke conversion kits for applications originally using a divorced-style choke. I used to think that there was no way to convert a divorced choke style carburetor (e.g. all 66-72 Holley carbs used on Corvettes, Rochester Q-Jet Model 4MV, etc.). I was right about that; there IS no way to covert such carbs. However, there are available manifold mounted conversion units which effectively convert the APPLICATION to electric choke.
            Except for divorced choke operation, one is a lot better off with NO heat cross-over. Of course, without the cross-over one has to be sure that no heat riser (or, a "gutted" heat riser) is used.
            • Frank C.
              • January 1, 1986
              • 277
              Re: p/n 14011058
              Joe...what about using these heads on an AFB carbed engine? don't AFB carbs need that source of heat?
                • 43241
                Re: p/n 14011058
                Frank-----
                If they need it for any other reason besides, possibly, choke operation, it's news to me. Actually, I think that most AFB carbs use a hot air or electric choke.
                • Frank C.
                  • January 1, 1986
                  • 277
                  Re: p/n 14011058
                  Joe....I was referencing the bakelite spacer that went under the carb that the exhaust passed thru...Frank
                    • 43241
                    Re: p/n 14011058
                    Frank-----
                    If you're talking about the carb pre-heat set-up used on some cast iron manifolds used with AFB carbs in the early 60's, I think they do more harm than good. Certainly, they've destroyed a lot of carburetors. I'd plug the holes in the manifold with cup-shaped, drive plugs or drill and tap for NPT, allen head plugs. This will "inactivate" the carb pre-heat. It MIGHT be a problem if you drive the car a lot in ultra cold weather. Otherwise, I think it will be a benefit. Along with unleaded gas, your AFB might be "immortal".
                    You can and should still use the bakelite spacer along with the gasket and baffle.
