1966-1968 distributor lubrication - NCRS Discussion Boards
  • Chuck R.
    • April 30, 1999
    • 1434
    Last night I cleaned up my mystery 1966, 67, 68 distrubutor so all is ready when the re-build parts arrive.
    In order of disassembly, after the breaker plate was removed, I found a felt washer setting on a plastic seal and a mystery material below it.
    This material appeared to be fiberous in appearance but easily fell apert when touched.
    Was this well area packed with heavy grease and it's just all dried up, or was it a felt type material that has desintergrated from age.
    Thanks, Chuck
    • 15696
    Re: 1966-1968 distributor lubrication
    It's just the remnants of the grease that lubricates the upper shaft bushing. The oil drained away/evaporated long ago. Grease is an emulsion of oil and solids. What you found is typical. The oil is long gone leaving behind the solids from the grease. Replace it with a NGLI #2 general purpose grease.
    The felt seal should be saturated in oil, then allowed to drain. It provide lubrication for the breaker plate which rotates in response to the vacuum advance control.
    • Chuck R.
      • April 30, 1999
      • 1434
      I was also told by a Gent that it may also have been a blend of saw dust and oil as well.
      The material DID have the texture of dried out fine sawdust and oil.
      Either way, I'm packing it with grease and calling it a day.
      Thanks Dukester,
      Chuck
      • Mike M.
        • May 31, 1974
        • 8396
        i seem to recall a thin washer shaped ring of foam under the felt seal on some old distributors i've rebuilt in the past. anyway, take dukes advice and pack it with grease. mike
          • 15696
          No, it's not sawdust. If anyone wants to take a deep dive into grease technology google on "National Grease Lubricating Institude".
          • Chuck R.
            • April 30, 1999
            • 1434
            Re: No thanks, your word is enough Duke *NM*
            • Chuck R.
              • April 30, 1999
              • 1434
              Re: Yup, what Duke said *NM*
              • Jim T.
                • March 1, 1993
                • 5351
                (Message Deleted by Poster)
                • Jim T.
                  • March 1, 1993
                  • 5351
                  informative article at www.tispecialty.com/articles/article6.htm about C2 and C3 distributors by a professional rebuilder.
                  • Chuck R.
                    • April 30, 1999
                    • 1434
                    Re: Thanks Jim
                    I tried a few times to locate this in the archives and gave up.
                    There HAS to be a way to clean up the search process. Theres so much good information tucked away there and it's a crap shoot if you find anything!
                    Sorry I'm ranting.............Thanks again Jim,
                    Chuck
