c2 clutch fork problems - NCRS Discussion Boards
  • Bill S.
    • January 31, 2007
    • 396
    i mocked up mt muncie trans and 444 bellhousing for my L72 to check that all worked smoothly before i intalled the trans. it seems to bind up. do i need to adjust the ball stud? are there different length ball studs? are all the forks the same as ? it seems the throw out bearing is not on center and the fork leans back to the rear more than it should. bill
    • 43232
    Re: c2 clutch fork problems
    bill-----
    Corvette ball studs are non adjustable. So,you have no options there. There were 2 different length ball studs----1-3/8" and 1-1/2". Yours originally used the 1-3/8" stud. However, that stud was discontinued many years ago and replaced by the 1-1/2" stud. It should work perfectly for you.
    Check to be sure that you have the release bearing properly mounted on the fork. The "tangs" of the spring should be WITHIN the groove; not outside of it.
    • Bill S.
      • January 31, 2007
      • 396
      joe within the groove?
      sorry for 2 post at the same time i am really desparate. after dragging my feet for months i finally have the ambunktion to finish it up . i think you are on to somthing can you explain how the bearing fits on the tang?
        • 43232
        Re: joe within the groove?
        Bill-----
        Steve's pictures above describe it perfectly.
        • Clem Z.
          • January 1, 2006
          • 9427
          also remember if the front bearing retainer
          that the TO bearing slides on is aluminum get a steel one because the aluminum ones cause the TO bearing to stick.
            • 43232
            Re: also remember if the front bearing retainer
            clem-----
            I think he's in luck on this one. Only 1963 used the aluminum retainer. I don't think that an aluminum retainer was ever made that would fit 64+ Muncie transmissions.
