Split Ring Cables - Battery Disconnect - NCRS Discussion Boards
  • Erv M.
    • February 21, 2007
    • 445
    Don't fallout of you chairs laughing but with the split ring battery cables, E69 top post battery what type of disconnect should you use? I am looking at the Paragon catalog page 70. Will the top post/knife #5083 fit inside the battery compartment with the door closed.
    • 15606
    Re: Split Ring Cables - Battery Disconnect
    You will have to hear from some 1969 owners to be sure, but I believe since the battery terminals face the front in that application the knife blade switch will not fit. That is too bad because the knife blade switch is superior to the green knob.
    • William L.
      • December 1, 1988
      • 944
      Erv
      I like the knife type but it will not fit under the lid, I had to use the screw type, it's better than nothing.
      Bill
      Bill Lacy
      1998 Indy Pacecar
      • Donald B.
        • May 31, 2004
        • 299
        Only a fool would laugh at your question. The only stupid question is the one you don't ask. I've asked a lot of questions that boarder on the stupid - but someone on this Board has always been nice enough to answer them.
        • Erv M.
          • February 21, 2007
          • 445
          With using an original split ring cable how do you attach it to the disconnect. Does the split ring fit the round protruding stud behind the green knob?
          • Stephen L.
            • May 31, 1984
            • 3158
            Yes. The disconnect fits the NEGATIVE battery post and the negative lead fits the disconnect.
            • Jeffrey S.
              • May 31, 1988
              • 1888
              I have a green knob disconnect on my early '69 with a Restoration Battery. The knob devise is connected to the negative terminal and it fits nicely under the lid.
              Jeff
