63-82 Steering Box Lube - is 14oz enough? - NCRS Discussion Boards
  • Geoff C.
    • May 31, 1979
    • 1613
    What capacity is needed for a dry box?
    Thanks & Happy Valentines Day.
    Love & Kisses
    Geoffrey Coenen
    PS What about C1's also?
  • Jeff W.
    • November 1, 2005
    • 272
    Re: 63-82 Steering Box Lube - is 14oz enough?
    Doc, I just rebuilt my 72, but it was not totally dry, and there was very little left. I would think that more than 14 oz. would be needed if dry.
    By the way, thanks for taking care of the delco sending unit for my gas tank that I had an issue with. Deb has taken care of me through this winter project and I have been more than pleased with the products.
    Jeff
      • 43229
      Geoffrey-----
      My recollection is that it takes a full 14 oz tube + 2-4 ounces from another tube.
      • Geoff C.
        • May 31, 1979
        • 1613
        Thank you Gentlemen; Much appreciated *NM*
        • Harmon C.
          • August 31, 1994
          • 3228
          Re: Thank you Gentlemen; Much appreciated
          The rebuilder who taught the class at Bloomington used a heavy high heat grease. It was more like wheel bearing grease. It would be interesting to know what Bairs and other rebuilders use. I have done about 10 with the heavy grease for my cars.
          Lyle
          • Terry F.
            • September 30, 1992
            • 2061
            There was a technical bulletin put out that described the change to grease vs heavy oil (I call it grease too). If you are very careful and do a nice job of rebuilding the unit, you can get by with the heavy oil. Terry
