I'm trying to clarify exactly what characteristics are correct for the PCV hose clamps and fuel line hose clamps on my 67. I have been told during judging that the original clamps have "square" ends on the ears and that the ears are "long." The reproduction clamps presently on my car do not meet these criteria.
The photo below shows what I have been told is a correct PCV hose clamp for 1967. Note that only the two outboard ears are squared, while the center ear is rounded. Also, the outer ears are not really square, since they have a small radius on the inside corner. The length of the outer ears, measured on the back side from what would be the surface of the hose, is about 1/4 inch.
I have seen other styles that are claimed to be "correct," with all three ears squared off and the ears generally shorter than the two outer ones in the photo below. My questions are as follows:
1) Is the clamp in the photo below a correct PCV hose clamp for 1967?
2) Are there other variations that are also considered to be correct?
3) Do the smaller fuel hose clamps have the exact same characteristics as the one in the photo below, or are they different? If someone could post a photo of a correct fuel line clamp, I would very much appreciate it.
