4 speeds - NCRS Discussion Boards
4 speeds
  • mario diteodoro
    4 speeds
    I have two 4 speed geag boxes i need decoded and the gear ratios, first is a b&w #wj51-2210027 and the other is a muncie #p080b180155. Thanks Mario.
    • 43240
    Re: 4 speeds
    Mario------
    I would say that the Borg Warner T-10 was produced on October 5, 1961. From the information provided, I can't tell the ratio.
    The Muncie date coding does not look correct to me. However, it MAY be a 1970 model year transmission and the close ratio (M21) variant.
    • Wayne M.
      • March 1, 1980
      • 6414
      Need more Muncie info
      Can't help you on the B-W.
      What's the part # cast on the top line driver side maincase; ie. 3851325, 3885010, 3925660 or 3925661 ?
      Where is the P assembly date located ? Are there 10 splines on the input shaft, and are there none, 1 or 2 circumferential rings.
      is the "b" at the end of the P number, or is it located at the start of the 180155 ?
      Pics would be preferred, but if you could provide this info, we can go from there.
