RR front control arm bushings...C2 - NCRS Discussion Boards
  • Wayne C.
    • November 1, 1978
    • 289
    Re: RR front control arm bushings...C2
    Forgot to mention... after the rubber is burned out of the bushings, a hacksaw is inerted through the old bushing outer sleeve, clamped in the hacksaw, and a cut made lengthwise through the side wall of the bushing. Then you use a chisel to "fold the bushing sleeve inward to break it's grip and then drive it out of the A-arm.
    I've seen Joe's method with an air chisel used at an auto repair shop, and that worked very well, "walking" the bushing out of the arm.
      • 11651
      Re: Repro ball joints
      China.
      • Terry F.
        • September 30, 1992
        • 2061
        #18
        China *NM*
