I assembled my motor about 18 months ago and it has set dormant since then. Today, I hooked up the battery, primed the oil pump, reinserted the distributor, removed the spark plugs, inserted oil in the cylinders and valve springs and turned the key. Yes, it turned over nicely and showed oil pressure on the gauge.
Here is the problem and maybe you can help: I am only getting oil through one push rod up to the rocker. No other rockers are showing oil pressure. The push rods are clear.
My first hunch is that the lifters have not pumped up. However, I have been using the starter to turn the motor over, off and on, for the last hour. No success yet.
Any ideas?
MRJ
Any ideas?
MRJ
