73 rear spring - NCRS Discussion Boards
73 rear spring
  • Mladen Bay
    73 rear spring
    I bought the assembly manual. All the numbers are a bit confusing, I could not figure out what the correct leaf spring for 1973 corvette small block should be. Thanks for the help.
  • Robert E.
    • April 1, 2004
    • 398
    Re: 73 rear spring
    Mladen,
    Not sure if HD suspension was available in '73, but if it were, it would have 7 leafs (leaves), standard suspension has 9.
    Hope this helps
    Robert
    • Mladen Bay
      Re: 73 rear spring
      9 leaf spring is on there now, and needs to be replaced. I think they had HD springs in 73, but would that be correct. Does anyone know of a good source for correct springs. Paragon has only aftermaket springs.
      • Gary B.
        • February 1, 1997
        • 7028
        '73 rear spring; repro and used originals
        Mladen,
        While there is no repro spring that is 100% cosmetically correct, Eaton Detroit Spring makes a decent spring that many people report being happy with. If you want 100% correct cosmetics, you'll need to buy a used spring. Try Crane's Corvettes or America's Finest Corvettes in California or Pacific Corvette in Washington state. I don't have contact info handy, but google them for details. Any of those places should be able to sell you an original 7-leaf or an original 9-leaf that should be correct for your '73. You need to know which one to get though.
        Gary
          • 43232
          Re: 73 rear spring
          Mladen-----
          The only way that you got a HD rear spring (i.e. 7 leaf) for 1973 is if the car was equipped with the Z-07 performance package. Only 45 cars were so-equipped.
          • Gary B.
            • February 1, 1997
            • 7028
            Good catch, Joe *NM*
