69 strike - NCRS Discussion Boards
69 strike
  • Brad S.
    • July 31, 2005
    • 227
    69 strike
    This is my first post so please bear with me. I am in the process of restoring a 69 L-36 4 speed coupe. My motor was built March 24 ( pre strike) and my car was built June 18 (post strike). My question is regarding the 7029215 Q-Jet. Would a January date be too early? I think it would be about right if the strike hadn't happened. I was just wondering if St. Louis continued to get parts while the strike was going on possibly making the Jan. date a little early. I know tis is covered somewhere in th archives but I can't find it.Thanks for any help.
    • 43221
    Re: 69 strike
    Brad------
    A January carb date would "work" for a June-built car under NCRS and NCCB judging standards. So, there's no need to make it more complicated than that. Under any circumstances, it would be possible for a January-manufacured carb to wind up on a June built car. That's why NCRS and NCCB have the "6 month rule". In your case, it probably more likely that a June-built car would have originally been fitted with a January-manufactured carb.
    • Brad S.
      • July 31, 2005
      • 227
      Re: 69 strike
      Joe, Thank you
      • Terry F.
        • September 30, 1992
        • 2061
        Re: 69 strike
        Brad, are your engine lift brackets still installed on your engine? Thanks, Terry
        • Rob M.
          NCRS IT Developer
          • January 1, 2004
          • 12761
          Re: 69 strike
          Terry,
          Mine are still there on my L36, do you want specific pictures?
          greetings,
          Rob.
          Rob.
          NCRS Software Developer
          • Terry F.
            • 2061
            Re: 69 strike
            Rob,
            Take a look at them. They will probably have some identifying features. I expect you will either find a part number on them like 3989829 and/or 3994055 (front large bracket) and/or a symbol like a "U" or "C with an M" in the middle. You may also see a 1/8 inch hole drilled in the front bracket depending on the bracket.
            On the rear bracket, tell me if it is straight or bent or if any of the corners have been nipped off. Hard to discribe but the corners could be sort of cut off.
            Close up pictures would be great! Thanks a bunch, Terry
            • Terry F.
              • 2061
              Re: 69 strike
              I forgot to mention that if you take picutures you can send them to tfringo@aol.com
              Thanks, Terry
              • Rob M.
                NCRS IT Developer
                • January 1, 2004
                • 12761
                First photo of front bracket
                No number found on the front bracket. The rear is really so well build-in that it is impossible to study and photograph it as long as the engine is fitted with the radio shielding...
                greetings,
                Rob.
                Rob.
                • Rob M.
                  NCRS IT Developer
                  • January 1, 2004
                  • 12761
                  Re: 69 strike
                  The other side of the front engine lift bracket...
                  greetings,
                  Rob
                  Rob.
                  • Terry F.
                    • 2061
                    Thanks! Terry *NM*
                    • Brad S.
                      • July 31, 2005
                      • 227
                      Re: Thanks! Terry
                      Terry, I have 2 front brackets 1 came with the car and 1 is off a 69 396. The one that came with the car does not hahe any markings and has a hole alittle less than a quarter Towards the rear. The one off the 396 has 3969829 on the back side and an 1/8'' hole toward the front.
                      • Terry F.
                        • 2061
                        Re: Thanks! Terry
                        Brad, is there any way you could send me a picture? Yours is a 69 390hp?? Terry tfringo@aol.com
                        • Brad S.
                          • July 31, 2005
                          • 227
                          Re: Thanks! Terry
                          Terry, right now my camera is in Puerto Vallarta And won't be back till next week. If you can wait I will try to do it then. Thanks Brad
                          • Terry F.
                            • 2061
                            Re: 69 strike
                            Rob, is your intake cast iron? Just wondering. Terry
                            • Rob M.
                              NCRS IT Developer
                              • January 1, 2004
                              • 12761
                              Re: 69 strike
                              No it is aluminium but painted orange incorrectly (I just found out recently)...
                              greetings,
                              Rob.
                              Rob.
