clutch linkage question - NCRS Discussion Boards
  • Howard Nardick
    I am assembling my `69 and am wondering which is the correct way for the rod that attaches between the z-bar and the fork to attach at the z-bar?? funny bent clip in (towards the motor) or out towards the frame...
    .....thanks in advance!! ....HN
    Re: clutch linkage question
    Howard -
    It should show the correct orientation of the rod in UPC 7 in your Assembly Manual.
    • Howard Nardick
      thanks for your response, but if I had the manual I wouldn`t need to ask...
      • Stephen L.
        • May 31, 1984
        • 3158
        Rod end should point toward the engine for both rods on the "Z" bar
        • Howard Nardick
          THANK YOU!! *NM*
