Hard top needed for judging? - NCRS Discussion Boards
  • Jon Elliott
    I'm having my two top 62 judged this weekend in Vancouver, Wa. From reading the judging manual, I understand only one top is judged. I have the soft top in the car and intend to have it be the top to be judged. My question is since the car is a two top car, to I need to bring the hard top as well?
    Thnx, Jon
    Re: Hard top needed for judging?
    Only for a Performance Verification do you need both tops on the car. You can Flight with your choice.
    • Mike M.
      • May 31, 1974
      • 8396
      jack: if the c-1 was a hardtop only car, the owner wouldn't need a soft top assembly for a PV. unless the rules have changed, i don't recall a two top vette needing both tops for a PV although if it were a power top c-1, then i'd expect the soft top to be present and not just show up with a hardtop. let me know if i stand corrected. regards, mike
      • Lyle24961
        I have seen the hardtop being removed and the cloth top checked during a PV. If you can tell it had both tops I think you need them both on a PV.
        Lyle
        • Jon Elliott
          Excellent, I am only going for flight, so the hard top gets to stay at home! Thanks guys
          • Page C.
            • February 1, 1979
            • 802
            Hi Jon,
            You can leave the top at home but leave the hardtop wrench in the glove box.
            Page Campbell
            • Jon Elliott
              Great reminder!, it is in the glove box. Thnx, Jon
              • Lyle24961
                Jon
                You should show your Corvette with the top that will give you the most points. I had a Bowtie car that I would flight judge with the hardtop because the original soft top had a few issues.
                Lyle
                  Don't forget the two little black rubber sealing washers - if the hardtop is on, they should be in the bag with the wrench; if the soft top is on, they should be between the hardtop bolt head and the ferrule on the deck lid.
