69 Front Air Dam Fasteners - NCRS Discussion Boards
  • Allen N.
    • Today
    I have searched the archives, studied the judging manual, ordered nuts and bolts from three suppliers, and bought nuts from a Chevy dealer trying to figure out what is correct.
    The bolt I believe is closest to correct is from Paragon. It is a 1/4-20 X 9/16" blot with a capture washer that is black oxide plated. There is an additional 3/16" on the end that is a smaller diameter and non-threaded. I believe if I take my Dremmel and cut off this 3/16" and plate the end I cut off that it will be very close to original.
    The nut Joe Lucia says is closest to correct is part no. 9439915. This is a black oxide plated flare nut, and this appears to be as close as you can get to original. Some people seem to believe the gold cad plated nut with attached washer from Paragon is correct.
    There is a question on the plating of the bolt and nut. The judging manual says black oxide, but Joe Lucia said black phosphate in the archives.
    I would appreciate any comments on my findings.
    Allen
    • 11648
    Re: 69 Front Air Dam Fasteners
    Allen,
    Here's a picture of the fasteners on my 72, if that helps.
    Patrick
    • Allen N.
      • Today
      Patrick,
      Thank you for the picture. Is this an original bolt and nut? It looks like the nut is gold cad plated. What is the coating on the bolt?
      Allen
        • 15606
        I see black *NM*
          • 11648
          No, it's black. I've never removed the wax from previous owners, either.
          I'd guess black phosphate, but really it's semantics on a part that small. You'll never tell which is which from the front, and as long as it appears corrct that will be fine.
          Patrick
          • Allen N.
            • Today
            Thanks Patrick!!! NM *NM*
