c-4 question--front spring - NCRS Discussion Boards
  • Mike M.
    • May 31, 1974
    • 8383
    got a non-ZR1 c-4 front suspension under the 41 willys pickup. need stiffer front spring that will lift the front end about 2" higher than the current used c-4 spring . any thoughts. it'll be an autox Willys so i'm not too, if any, concerned with ride quality. thanks, mike
  • William C.
    • May 31, 1975
    • 6037
    Re: c-4 question--front spring
    Mike are you using Z-51 spring or Std?
    Bill Clupper #618
    • Joe C.
      • August 31, 1999
      • 4598
      Mike;
      Z-51 spring will give same ride height as standard spring with much harsher jounce rate. The 1984 Z51 spring, in particular, has a much higher rate than the 85/88 Z51 spring. Have you considered keeping the standard spring with spacers?
      Joe
      • Mike M.
        • May 31, 1974
        • 8383
        is placing spacers between the spring and the front x-member the way to go?thanks, mike
        • Joe C.
          • August 31, 1999
          • 4598
          Mike,
          I'm not sure what spring rate you're looking for, but AFAIK, the Z51 spring will give the same ride height as the standard spring. With that in mind, I see no other way to increase the front ride height, other than with spacers, unless you change to a non Corvette spring.
          I am not sure whether the ZR1 spring will work for you, either, because I don't know the weight differential between the LT5 and the L98. The all aluminum alloy Merc engine has larger heads than the iron L98, so the weight diff is probably minimal.
          Joe
          • Mike M.
            • May 31, 1974
            • 8383
            thanks joe and clup. think i can put a spacer between spring and front x-member. will also check and see if the 84 Z-51 spring is still available from GM . stiffer spring will be beneficial for Willy's autox future. thanks again, mike
