57 soft top frame - NCRS Discussion Boards
57 soft top frame
  • paul bowers
    57 soft top frame
    i have a 57 with soft top and I know the frame needs some repair, so can I
    ship it somewhere and have the old top taken off and just have the frame repaired I can have the new soft top installed local I want the frame correct before I install the new top any ideas or suggestions
    thanks
    paul
  • Mike M.
    • May 31, 1974
    • 8397
    Re: 57 soft top frame
    it would be difficult to repair the side rails(which are usually bent) without having the car present. its not that difficult a job. seems to me that it took a weekend to remove, disassemble, straighten bent pieces, glassbead, re-bush, paint and adjust the top to the car(windshield and door glass up). good luck, mike
    • Jerry C.
      • November 1, 1995
      • 741
      Might try Coffman Corvette at 888-774-0220
      • paul bowers
        THANKS JERRY I DID E-MAIL THEM
        PAUL
        • paul bowers
          mike
          its that there may be parts that are missing or just beond me abilities, just wanted to find a firm that could take frame and make it correct seems a firm would have a jig to place frame on just for the purpose of making frame correct
          thanks
          paul
          • Mike M.
            • May 31, 1974
            • 8397
            paul: if your 57 is pre about vin 4000 (doesn't have the metal reinforcements behind the kick panel), the dash may have drooped a bit whcih will tilt the windshield backwards at its top. if that's the case, a soft top bow assembly restored using a jig may or may not fit your car.good luck with coffman. they have a good reputation. mike
