1968 TI Distributor Casing Casting Nos - NCRS Discussion Boards
  • Tony 44494
    i have 2 distributers that are supposed to be for the car.
    one casing is cased 820 and the other is 240
    does anyone know what is the right on if any
    i dont know if these are the dates or just castings
    there are no tags
  • Wayne M.
    • March 1, 1980
    • 6414
    Re: 1968 TI Distributor Casing Casting Nos
    Tony -- I think these are just casting mould numbers (usually upside down, near the tach drive). Just checked 5 T.I. distrib's and the nearest I have is "231" on a 1968 435hp 1110296 8_B_26. A 1970 (0_J) has "350", and a '64 (4_C)has "60" and a 1969 (9_D) has "350". Interesting to note that in the summer (?) of 1970, they started to drill the casing end of the tach drive (driven) gear thrust surface to install a plastic (nylon ?) wear button. The 0_J has this but another non-T.I. 0_B does not. Also, the 0_J has the mould # in line with the shaft (not upside-down). So if any pattern here, it's that the mould # increases with time. Another 263 ball bearing distr has # "41" but cast right-side-up.
    Another way to narrow it down is if the vac advances are original, the 3-digit # may tie-in with a particular factory distrib for 1968.
