Part No. 3820040??? - NCRS Discussion Boards
Part No. 3820040???
  • Ralph E.
    • February 1, 2002
    • 905
    Part No. 3820040???
    Is there something special about this bolt.
    What size is it? Length, Diameter, Head?
    Can not find it any where.
    • 43238
    Re: Part No. 3820040???
    Ralph-----
    It's a PRODUCTION-only fastner first used for the 1963 model year. It was never available in SERVICE. I have no specs on it. However, I can tell you that it's not a general-use fastner. It was designed for specific application(s).
    • Ralph E.
      • February 1, 2002
      • 905
      Joe,
      I found the bolt. It is for the tail end connection for side exhaust through the insulators. Since sidepipes were not an option in '63 I guess the bolt had other uses.
      Hopefully someone will know the diameter. I would expect 3/8".
        That bolt was also used from '63-'67 for the fuel tank straps on both the standard and N03 tanks - it's a 3/8"-16 x 2-1/4" zinc-plated carriage bolt.
