67 Inner Fender Splash Shields - NCRS Discussion Boards
  • Donald W.
    • August 12, 2013
    • 190
    Need help in installing the splash shield staples. Anyone have any procedures to install them so they look factory correct.
    Thanks for your help,
    Don
  • Stephen L.
    • May 31, 1984
    • 3156
    Re: 67 Inner Fender Splash Shields
    Align your splash shield to the fender opening. Using a very small drill bit carefully drill thru the shield from under the fender using the existing holes as a template. Insert the new staples from the engine side and roll the ends like a staple using a small needle nose plier. The staples will have a raised hump on each staple "leg" when you are finished.
    • Donald W.
      • August 12, 2013
      • 190
      Thanks Steve *NM*
        Don't use the stainless staples that usually come with them - they're hard to work with, and are incorrect. Make your own from 16-ga. galvanized steel wire (blister-pack item at the hardware store).
        • James W.
          • December 1, 1990
          • 2652
          I'll vouch for the stainless steel staples being a b#$%* to work with. I installed new seals on my original shields and had a less than pleasant experience bending the staples. John, thanks for the tip regarding the 16-ga. galvanized wire.
          James West
          • Donald W.
            • August 12, 2013
            • 190
            John,
            Will use the galvanized wire type, do you know if Long Island Supply has these.
            Thanks always,
            Don
            • Mike M.
              • September 30, 1999
              • 710
              I used LIC staples. I found them a little hard to bend but got the hang of after a few. It seems to me that they are SS but are magnetic. Mike
              • Bryan L.
                • June 30, 1998
                • 397
                On the last set I did I found 16 ga. galvanized wire at Walmart in the hobby section. I bent the new ones up with duckbill pliers and they worked fine and are really easy to work with. I tried first with the ones from LICS but found them too hard to work easily.
                BL
