going with the LT-1 cam, now I need head work?
I've decided to go with the LT-1 cam. I've informed the machine shop where I'm getting my heads rebuilt & sent him the specs for the cam. He said in oder to run that aggresive of a cam I will need new springs, retainers and locks and adding a set of spring seats as well as cut the spring pockets open to accept the larger diameter spring.
He said if I go with a cam with under 450" lift I can use the same style spring with a more aggresive rate on it and reuse all of my retainers and locks over.
Is this sound advice? And is this necessary?
As far as I know, the heads I'm having rebuilt are the original (are at least matching #'s 993 castings). So I'm not sure why I would need all this extra work if my car originally came equipped with a solid lifter cam?
