Replacing the rear brake block on a 72 - NCRS Discussion Boards
  • Matthew S.
    • August 31, 2005
    • 64
    I'm in the process of rebuilding all the calipers on my 72. The rubber brake hoses were old so I figured I'd replace them as well. I took off the left rear brake hose and found that the threads in the brake block were stripped so I now need to replace that block. I looked at it and I can get a wrench on the brake line that goes to the right rear brake but I don't see an easy way to get a wrench on the line that comes from the front of the car. Do I have to pull out the entire brake line to replace the brake block or is there some other trick to removing the front line?
    Thanks - Matt
  • Mark #28455
    Re: Replacing the rear brake block on a 72
    IT's been a while, but I think it was easier once I removed the rearward and right side lines, then released the block from its mounting bracket. I then was able to move it to a position that allowed better access. Just make sure to note the orientation of the lug that goes through the mounting bracket and position the new one similarly.
    Hope this helps,
    Mark
    • Matthew S.
      • August 31, 2005
      • 64
      Thanks Mark - I've soaked the brake block and lines with PB Blaster. Hopefully that will loosen any rust and I'll have enough access to get the lines off without having to replace them.
