'62 generator rebuild- terminal question - NCRS Discussion Boards
  • Rob Edwards
    I have been having trouble with the generator not charging lately. Since the brushes were visibly worn I decided to pull it apart and install a rebuild kit. Turns out the brushes were asymmetrically worn but not down to the holders, so the commutator was not scored. FWIW, the armature has a big 1940161 stamped in it (cut n' paste the URL below), is that a Delco part #?
    https://webfiles.uci.edu/redwards/public/generator%20armature%20%23%201940161%203-11-06.jpg?uniq=90r4cn
    Anyway, the terminal to which the brushes attach was loose in its hole and had worn about half way thru (vibrations?) The rebuild kit included a new terminal post and a circular plastic sleeve to insulate it from the case. I could not see how to slip the sleeve into the hole on the inside of the case, there's a riveted strap (which holds the brush mount) that is in the way. As you can see from the pic, there's now a prominent white plastic ring sticking out around the post on the outside of the case. Though the generator is now working great, I'm sure I assembled it wrong- does anyone know how this insulating sleeve SHOULD be mounted? I can post a pic of the inside of the case illustrating this if anyone's interested. Thanks!
  • Eric J.
    • March 1, 1980
    • 771
    Armature Picture repost
    Rob had some trouble with your armature link so I cleaned it up and reposted it for you. Eric
    • Mike E.
      • February 28, 1975
      • 5140
      Re: '62 generator rebuild- terminal question
      Rob--
      Sure looks acceptable to me the way you have it installed. It has to stick out some--it's job is to insulate the entire terminal from the case. Don't lose sleep over it!
