1968 Corvette 435 water pump pully PN? - NCRS Discussion Boards
  • Jon H.
    • January 1, 1999
    • 150
    what is the correct water pump pulley for a 68 435 car. Thanks.
  • Jack H.
    • April 1, 1990
    • 9906
    Re: 1968 Corvette 435 water pump pully PN?
    Check your copy of the Assembly Instruction Manual. You ought to find a drawing in the engine section depicting all the possible pulley and belt combinations for the various car configurations (SB vs. BB, with A/C, with PS, Etc.).
    • Steve Wallach
      It's the same for the 435 cars as the others...
      It's a cast iron, two groove pulley.
      I don't have the part number here, but I have a 435 1968, 4spd, No A/C car
      with PS.
      It's the same pulley as my 67 390hp/ PS car
      Steve
        • 43260
        Steve------
        You're referring to the CRANK pulley; the waterpump pulley was never made of cast iron for this or any other application.
          • 43260
          Jack and Jonathan-----
          I don't think that you'll find definitive information on this one in the AIM. I believe that early 1968 with 427 may have used 2 pullies sandwiched togther. These may have been GM #3848904, a 2 groove rear pulley also used on some small blocks in combination with a single groove GM #3883235 front pulley, also used on many small blocks.
          Later 1968 used a 3 groove pulley of GM #3889372. I don't know when the change was made and/or if there were actually any of the early configuration actually assembled.
          The early, sandwiched configuration involved pullies that were larger in OD than the later 3 groove pulley. I believe the smaller diameter, 3 groove pulley was used in order to increase fan speed and resultant cooling.
          • Steve Wallach
            Hi Joe,
            Sorry, I had Power Steering pullies on my mind I think. The WATER PUMP pulley
            for the 427 435 is a THREE groove pulley, They are RARE (Pressed steel)you can
            get them from Paragon as a GM Restoration part or now and then on Ebay. The last one I saw go on Ebay was about 240.00 The GM retoration part from Paragon is 200.00 I think. I believe (from memory) the pulley part number ends in a 721?
            Steve
            • Steve Wallach
              From Paragon,
              item number 1762, states it includes the original GM part number "3889372 BF".
              200.00
              Cheers,
              Steve
                • 43260
                Steve-----
                Yes, as I mentioned in my post in response to another in this thread, the GM #3889372 waterpump pulley was used for "later" 1968 big block applications (except L-88). This pulley is a 3 groove pulley of 5-1/2" OD. It was used for most 1968-70 Corvette BB application and was replaced in the mid 70's by GM #3995644. The latter is a similar pulley and 100% functional for the applications. However, it is configured a little bit differently than the 3889372.
                • Dick W.
                  • 10483
                  Joe you occasionally you will see the two piece pulley on a 68 or 69 on the judging field. Not real common
                  Dick Whittington
