'62 automatic bell crank finish - NCRS Discussion Boards
  • Gene M.
    • April 1, 1985
    • 4232
    What is the correct finish on the '62 automatic transmission kick down linkage that bolts to the back of the engine block with the transmission mounting. The part in question consist of a bracket providing the two pivot holes, attached with two 3/8 bolts and the rod bent with arms at each end. thank you
  • Mike M.
    • May 31, 1974
    • 8396
    Re: '62 automatic bell crank finish
    natural. mike
    • Roy B.
      • February 1, 1975
      • 7044
      or cad
      • Mike M.
        • May 31, 1974
        • 8396
        roy; haven't ever seen a cad plated bell crank for the powerglides but i haven't seen them all. have you got a cad plated example? mike
        • Roy B.
          • February 1, 1975
          • 7044
          It's a light cad look or some kind of coating, I just see and call it cad, they are all the same on Auto.and linkage and all 55 up Chevy Car Auto,
