Water pump pulley for 1966 AC, PS, A.I.R. - NCRS Discussion Boards
  • Craig C.
    • July 31, 1996
    • 27
    I would like to get my A.I.R. smog system going on my Calif. '66 300HP coupe with AC, PS and powerglide. It seems I need a third groove add-on water pump pulley to drive the smog pump. Do I need pulley #3883234, if so is it (or a replacement) available from GM or anywhere? For the smog pump, I managed to locate pulley #3890421, is this correct and how wide should the spacer be for my "third track" application?
    • 43221
    Re: Water pump pulley for 1966 AC, PS, A.I.R.
    Craig-----
    For your application, I believe that the GM #3883234 pulley was used. This pulley is reproduced by "The Pulley King", but I'd try to obtain it from one of his STOCKING dealers, rather than directly.
    I do not know the thickness for the spacer.
    • Dale S.
      • November 12, 2007
      • 1224
      Joe, Do you know who his dealers are?
        • 43221
        dale-----
        I think that Dr. Rebuild and Paragon are two of them.
        • Dale S.
          • November 12, 2007
          • 1224
          thanks Joe!
          • Craig C.
            • July 31, 1996
            • 27
            Thank you Joe and Dale, I will check with the vendors. Should I use smop pump pulley #3880800 or #3890421? The judging guide indicates the former while the assemply manual seems to indicate the latter (since I have C60 and N40). Craig
              • 43221
              Craig-----
              I think the GM #3890421.
              • Craig C.
                • July 31, 1996
                • 27
                Joe, Excellent, thank you!
                • Mark G.
                  • March 1, 2001
                  • 227
                  • Craig C.
                    • July 31, 1996
                    • 27
                    Mark,
                    Thank you, yes please let me know the thickness of your spacer, mine is 7/8". Do you use the 421 pulley (vs. 800), does yours connect to a third-track water pump add-on pulley as well?
                    Thanks, Craig
                    • Mark G.
                      • March 1, 2001
                      • 227
