1954 inspecition - NCRS Discussion Boards
1954 inspecition
  • Rob M.
    NCRS IT Developer
    • January 1, 2004
    • 12785
    1954 inspecition
    One of our members was so kind to do an inspection on the 'number matching car' of e-Bay item 4600450202. Check out this stamp pad and make up your own mind.
    other remarks:
    - Zoom in and you can see the block was restamped. Ran good but too quite...has (wrong) hydraulic lifters probably a passenger car block.
    - Wrong head number, as we knew.
    - Bottom of transmission. Part number? This is a V8 transmission, no modulator and a 14 inch dip stick.
    - Neutral safety switch...incorrect transmission mounting.
    - Differential. Didn't find MW has a part number of 3698050?
    Not much to say otherwise than the deal is off...
    greetings,
    Rob.
    Item 4600450202
    Rob.
    NCRS Software Developer
  • Roy B.
    • February 1, 1975
    • 7044
    Re: 1954 inspecition
    First off you CANT put a V8 PG behind a 6 banger
    • Geoff C.
      • May 31, 1979
      • 1613
      I don't know enough about 6 cyl to comment - But I'll open my big mouth...
      It was at a recent Carlisle event(s)
      It has that well intentioned NCRS sticker
      Needs air cleaners
      Needs that thing above ignition switch (same as my 56, but I CRS)
      Wiper transmissions on blue blanket are ?? to difficult to see
      No view of wiper motor area of firewall
      Washer system not shown
      Parking brake alarm jewel missing
      No rear license bezel
      Chrome on blue blanket not complete set
      License bumperette supports missing (perhaps on blanket)
      Deck lid trim & flipper moldings missing
      Upper door panel missing
      Heater missing
      Mirrors missing
      Tonneau cover snaps on dash rail
      No radio, (speaker on blanket), dash knobs and the switches ??
      Door edge trim missing
      Side chrome on blanket hard to see what shape
      Convertible top mentioned but not shown
      Rugs if new are questionable
      No jack, tools
      Radiator not shown
      Hoods or trunks with torn off patches of fiberglass are unusually indicative of the part being violently removed from the vehicle as in a collision.
      No VIN tag mentioned
      Geoffery Coenen
      • Roy B.
        • February 1, 1975
        • 7044
        Re: 1954 inspecition Its a E-Bay Dream *NM*
        • Robert S.
          • July 31, 2004
          • 377
          Can anyone help identify the cast iron powerglide with a shift pattern (front to rear) RLDNP, approx. a 14 inch long dip stick, no vacuum modulator and casing numbers on the bottom of case of 3708184 - GM5 - C or G 208 or 206?
          Bob
