62 Fuelie engine on Ebay - Restamp? - NCRS Discussion Boards
  • Loren Smith
    Belt sander broach marks?:
  • lyndon sharpton
    Re: 62 Fuelie engine on Ebay - Restamp?
    don't look to bad! it might pass the test.
      • 11643
      Broach marks seem to end where they'd be hidden under the head.
      Also, no VIN stamp, so it was never installed in a production line Corvette. At best an over the counter replacement, but I would guess it's been made into a "restoration motor" that the next owner can apply his own VIN to the pad.
      Patrick
      • mike cobine
        It is hard to tell, but it looks like a .040 over on the piston. If so, then there has been a lot of time to wear that much, so where are the rusted pits on the deck under the water passages?
        That implies it has been decked to have such a clean deck. and any decking would have wiped the lines that are nearly at the cylinder.
        The lines visible go back well enough, but I almost see a curve, but that could be illusion from a photo.
        • Craig S.
          • June 30, 1997
          • 2471
          Mike - says 0.020 over in the description.......may well be a belt sander pad job but includes a fuelie unit etc.......see the listing hyperlink below....this seller has several BB engines as well.......touting a new CNC machine for block prep.....looks like on this one he is selling for what the market will bear vs the BB's for high dollars.......Craig
          62 327/350 on eBay
          • John L.
            • 409
            If they are not really original -- they sure as heck look like they are.
              • 11643
              Again, no VIN code.
              • nancy charles
                IT LOOKS TO BE A RESTAMP FOR SURE . THE # 11 IS INCORRECT SHOULD HAVE A FLAG ON TOP OF THE # with out a foot on the bottom ? JUST MY OPINION .......
                • John M.
                  • January 1, 1999
                  • 1553
                  It is clearly a restamp, but the broach marks look real good. Whoever did them is a real craftsman!
                  Regards, John McGraw
                  • Mike E.
                    • February 28, 1975
                    • 5138
                    In 62 there were several different styles of several of the different digits used--the "1" was one of those--can't toss it out based on that.
                    • nancy charles
                      I must retract my statement about the #'s on the block. those #'s only apply to the serial # . but these #'s are still incorrect . the #s for the month of november should be the capitol letter ( II ) instead . THANKS
                      • nancy charles
                        SHOULD READ ( FII27RF ) . THIS WOULD BE CORRECT . IN MY OPINION ......
                        • nancy charles
                          FII27RF for some reason my computer will not post the capital letter ( I )WITH FOOT ON TOP AND BOTTOM ......THANKS
                          • Michael H.
                            • January 29, 2008
                            • 7477
                            I agree. The broach is hopelessly incorrect. The "one" and "two" characters are certainly not typical but I suppose possible. Also, as you mention, the lack of a VIN stamp would have to mean that this was a complete engine assembly sold through GM parts, not a fitted or short block assembly. Partial assemblies had no stamp at all.
                            • Joseph T.
                              • April 30, 1976
                              • 2074
                              Looks like he is a little confused about the correct or original 9 fin valve covers.
                              How do you put offset hole 56/57 9 fin valve covers on straight across 62 heads?
                              Without drilling extra holes?
                              Sounds like it might be a nice set of 9 fin covers if they have not been drilled.
