fuel boil temperture lower than before ? - NCRS Discussion Boards
  • Sander B.
    • March 1, 2005
    • 499
    it seems that the fuel or gas that is currently being refined boils at a much lower temperature than before
    is there a way to increas the boil temperture with some adative or are there some other fuels to be used ?
    or should i insulate the fuel lines ?
    got problems with the fuel injection at hot start
    • 15657
    Re: fuel boil temperture lower than before ?
    Actually, vapor pressures have been reduced over the years to lower evaporative emissions, and modern EFI engines will cold start well at lower vapor pressures than carbureted engines.
    Since gasoline is a mixture of literally hundreds of hydrocarbon species, there is not a single boiling point, like water.
    Gasolines have a distillation curve that shows the percent of species that reach their boiling points at various temperatures and the 10 and 90 percent points are used to quickly characterize a gasoline blend.
    For example the ten percent point - the temperature at which 10 percent by mass of the a gasoline's components have reached boiling temperature is typically in the range of 100F and the 90 percent point is usually around 300F.
    Winter blends have a lower temperature 10 percent point than summer blends to aid cold starting.
    FI hot starting has alway been a problem due to vaporization in the spider and the low cranking injection pressure. There have been various "fixes" over the years, many of which have been discussed in this forum.
    • Dale S.
      • November 12, 2007
      • 1224
      Stay away from fuels with methanol(Probably not the avaiable)or ethanol. D/
      • G B.
        • December 1, 1974
        • 1407
        Please read the archives on FI percolation.
        This was discussed within the last 3 months.
        • G B.
          • December 1, 1974
          • 1407
          Link
          Actually, it was back in June that we first had this little talk. How quickly I forget.
