1969 J56 Calipers - NCRS Discussion Boards
1969 J56 Calipers
  • Curt Worden
    1969 J56 Calipers
    Could anyone forward / post the 1969 J56 caliper casting numbers ? I could not find the info in the JM. Thank you .... Curt
    • 43240
    Re: 1969 J56 Calipers
    Curt------
    I believe that the J-56 caliper housings carry the same casting number as the non-J-56 variety for any given year(or group of years). J-56 caliper housings are identical to non-J-56 EXCEPT for the fact that the J-56 units have the pad mounting pin boss machined off and two holes drilled at either end of the brake pad mounting slot for J-56 pad retention. A non-J-56 caliper housing can be converted to a J-56 design by performing these simple operations.
    The above applies to the front calipers, only, though. The rear J-56 caliper housings were exactly the same as as non-J-56.
    • Curt Worden
      Thanks Joe....
      Does anybody know the casting numbers for the 1969 calipers ?
      Thanks, Curt
        • 43240
        Curt-----
        front, outer= 5452273
        front, inner= 5452270
        rear, outer= 5452284
        rear, inner= 5452281
        Remember, though, these are CASTING NUMBERS, NOT PART NUMBERS. The castings are MACHINED DIFFERENTLY to produce 7 different PART NUMBERS. Only the two front outers use the same part number. All 6 other positions use a unique finished caliper PART NUMBER. I could provide the part numbers but it's really irrelevant; they've been discontinued for years.
