Re: Timing Mark - NCRS Discussion Boards
Re: Timing Mark
+ More Options
Posts
  • Gene M.
    • April 1, 1985
    • 4232
    Re: Timing Mark
    Has the harminic balancer ever been replaced? The reason I ask is early vette and chevy engines use a balancer that has the keyway and the timing groove in line. Later chevies this relationship of keyway and groove are offset. Which do you have?
  • Michael
    Re: Timing Mark
    Thanks for the input. After finding out the previous owner had offset the distributor by about 180 degrees, I removed and replaced it correctly. When setting the time, however, I had forgotten to pull the vacuum line on the distributor and plug it before setting the time. The engine is now running smoothly at 6 degrees BTDC!
