C-1: Job Numbers/Crayon Marks - NCRS Discussion Boards
+ More Options
Posts
  • Paul B.
    • January 1, 2003
    • 8
    I've been following this message board for two years while working on my 61 project. The chassis is now complete while the body is receiving final prep for paint. I purchased the Quanta kit and applied the various paint inspection marks.
    I have questions about crayon numbers and inspection marks for my 1961 270HP chassis and engine. I located "359" in handwritten green crayon under the Instrument panel housing, which is the last three numbers of my VIN. Is "359" the job number for my car?
    Photos in Noland Adams Restoration Guide show two-digit, hand written numbers on the backs of the right cylinder head (page 144). Numbers also appear on the bell housing (page 182) and the body color written on the front crossmember (page 126). I've seen chassis restorations of later model years with "OK" written on the transmission and rearend housing. I know the referenced photos are from earlier model years. What is typical for a 1961?
  • Larry P.
    • June 30, 1999
    • 481
    Re: C-1: Job Numbers/Crayon Marks
    I think it's just by chance that you got the same job number as vin. I don't know if they started the numbering at the beginning of the model year or when. I understand that they started the job number over after 500.
    LP
    • Dennis A.
      • April 30, 1999
      • 1010
      Paul...
      My bet is the "359" is the job number, you might look on the inner door panels, seat back area, the transmission tunnel and the front of the firewall in the clutch/brake area to see if it was repeated. Larry is correct, the job numbers did start over at 500 stating in 1956.
